Can I get the default color map ?
Altenbach,
Thats the bunny!!  Many thanks, I was able to draw an image using the draw flattened pixmap's default color map and then use the invoke node get image method to return the resultant color map. I copied that to a constant and then used that constant to supply a color map to the write image to file routine.
thanks for the pointers
dave L
Message 11 of 11
(399 Views)
