Can I have 2 signals to output from one channel of the daq NI-USB 6009
Can I have 2 signals to output from one channel of the daq NI-USB 6009?
(2,866 Views)
That question does not make any sense. What exactly do you want to do?
(2,860 Views)
Yes. Connect 2 wires to the terminal. Smiley Very Happy
Honestly, like Dennis said, your question needs a little more information.
(2,852 Views)
My main problem is actually trying to control a futaba servo.I'm using the simulate signal.vi wired to the daq assistant to control the motor.However each time i run it, the motor rotates only in CCW. I'm finding a way to rotate it in CW so I was testing out with 2 signals.
(2,846 Views)
You need negative output to drive servo in another direction which is not possible by 6009.
You probably use some multiplexer IC with 6009 digital output to swap between AO and its GND.
(2,811 Views)
