Can I import a cluster with strings (or a byte array) from a Labview DLL into python (using ctypes)
I've saved a DLL (created in Labview) and i'm trying to import it into python, as per the guide, http://www.ni.com/white-paper/8911/en/
I can get other types except strings and arrays to read in from a cluster. I've reduced it to a very simple vi: a string goes into a cluster, the cluster is a function in the DLL i.e. the function is:
void TestCluster(Cluster *outputCluster)
I think I just don't have the correct Struct (?).
Has anyone done this? It might also be due to my little knowledge of ctypes in Python too.
Theres a similar item: http://forums.ni.com/t5/LabVIEW/Loading-Labview-DLL-from-Python-Hits-Error/m-p/2756534/highlight/tru...
Do I have to use the CLN? (I tried but couldn't work it out)
Sample Python code for the import:
#!/usr/bin/env python
import sys, os, string
from ctypes import *
class byteArrayStructure(Structure):
    _fields_ = [("dimSize", c_int),("bytes", c_uint8 )]
class clusterStructure(Structure):
    _fields_ = [("stringField", c_char*4 ),
                ("byteArray", byteArrayStructure )]
dll = cdll.LoadLibrary("test.dll")
libc = cdll.msvcrt
def testMain():
    retValue = 0
    try:
        clusterIn = clusterStructure()
        dll.TestCluster( byref(clusterIn) )
        print clusterIn.byteArray.bytes
        print cast(clusterIn.byteArray.bytes,c_char_p)
    except ValueError, Argument:
        retValue = "Error: " + str(ValueError) + "  " + str(Argument)
    return retValue
testMain()
(4,359 Views)
Is it possible to match up with the structs from the test.h file or am I missing something? (Does Labview allow this? or is the memory not accessible? or does the CLN have to be used?)
typedef struct {
    int32_t dimSize;
    uint8_t elt[1];
} Uint8ArrayBase;
typedef Uint8ArrayBase **Uint8Array;
typedef struct {
    LStrHandle elt1;
    Uint8Array unsignedByteArray;
} Cluster;
void __cdecl TestCluster(Cluster *outputCluster);
MgErr __cdecl LVDLLStatus(char *errStr, int errStrLen, void *module);
* Memory Allocation/Resize/Deallocation APIs for type 'Uint8Array'
Uint8Array __cdecl AllocateUint8Array (int32 elmtCount);
MgErr __cdecl ResizeUint8Array (Uint8Array *hdlPtr, int32 elmtCount);
MgErr __cdecl DeAllocateUint8Array (Uint8Array *hdlPtr);
(4,319 Views)
You overlooked the definition of
**Uint8Array
You see the double * in front?
That means it is a pointer to a pointer not just a pointer nor the entire structure entirely embedded in the cluster!
Same for the LStrHandle element in the cluster, that is also a pointer to a pointer to a similar structure.
Rolf Kalbermatter  My Blog
(4,302 Views)
