Can I increase the execution speed of this VI?
Ahhhh...OK, so now I see where you are getting your factor of 2.  Very interesting.  Another interesting thing is that if you add in the DBL conversion, this jumps to a factor of 10. Thanks a lot for looking at this guys.
Matt
Message 11 of 16
(872 Views)
I should also go ahead and point out that there are a couple more things that can be done: the conversion of the I32s, the division of the iTime by mTime and the subsequent conversion to a long Int can be removed from the top most loop to the outside of both loops.  The End.
Message 12 of 16
(866 Views)
The compiler might already do that behind the scenes (loop invariant code motion). One of the divisions is now on an array, so you might not gain that much...
Message 13 of 16
(863 Views)
Thanks, Altenbach.  I figure that but, might as well do what I can...
Message 14 of 16
(859 Views)
Personally, I never trust the compiler and would move it outside. 😄
Message 15 of 16
(857 Views)
I hear that!
Message 16 of 16
(854 Views)
