Can I install LV runtime without admin rights?
I want to install LV runtime without admin rights.  Is there any workaround that will allow me to do this?
J
(3,471 Views)
I don't think there is any way around this. This is more of a Windows thing than a LabVIEW thing.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,467 Views)
I haven't done yet but what about disconnecting the hhd
put in on a non administrated pc as data disk, installing RTE, then replacing in original pc...
a little bit exiting no   :smileywink:
Finally i don't know if its a good advice , it s up to you  🙂
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,462 Views)
Does anyone know of a hacky way to do this?  I have ABSOLUTELY no way to get admin rights. 😞
J
(3,460 Views)
J
Not that Windows security is the greatest but generally these types of things are not easy to bypass. They are security related afterall. I think you will need to contact you IT department about installing the runtime engine for you.
Mark Yedinak
LabVIEW Champion
(3,453 Views)
