Can I install LabVIEW 7.1 with NI Drivers from May2004 to PC with Windows7?
Very short, I think the answer is
  1. Get a newer Labview version
  2. Run an older Windows OS version on your PC
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 18
(3,107 Views)
And what about solution as install newer version of NI Drivers(after installing LV 7.1) to Win7 ?
Message 12 of 18
(3,091 Views)
The latest daq driver supporting LV 7.1 is DAQmx 8.9 which doesn't support Win7.
So there is no support for LV 7.1 with Win7 and there is no driver which supports LV 7.1 as well as Win7!
Christian
Message 13 of 18
(3,086 Views)
Christian
@Christian_M Is it some pages on the NI giving some information regarding Labview/drivers compabilety versus windows OS versions. I am sure I have ssen this some place
Message 14 of 18
(3,070 Views)
There is a NI-DAQ and LabVIEW Version Compatibility KB but there unfortunately you still have to look for each regarding the OS Support.
Christian
Message 15 of 18
(3,066 Views)
Christian
A thanks, that was page I was looking for. And via that site I also found this
http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB?OpenDocument
@krompacho Here is some links you better read
http://www.techsupportalert.com/content/how-windows7-vista64-support-32bit-applications.htm
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
Message 16 of 18
(3,061 Views)
http://digital.ni.com/public.nsf/allkb/B972242574D​4BB99862575A7007520CB?OpenDocument
added to my bookmarks. thank you!
Christian
Message 17 of 18
(3,055 Views)
@krompacho Using a dual boot system. You can have both WIN7 and XP on the same computer. That may be the best work around for the problem. The link below is a how-to for installing XP on a WIN 7 computer.
http://www.howtogeek.com/howto/8790/dual-boot-your-pre-installed-windows-7-computer-with-xp/
Message 18 of 18
(3,054 Views)
