Can I make LavVIEW run faster?
Ok, so if we assume that it is the buffer size and that I can afford to make it smaller, can I make it smaller, and, if so, how?
Message 21 of 28
(1,395 Views)
There is a VISA Set I/O Buffer Size function on the Serial palette.
Message 22 of 28
(1,390 Views)
Ok, so how would I determine the appropriate buffer size I should set?
Message 23 of 28
(1,381 Views)
hi there
the speed of transmission depends on the baud rate. this is the rate the bits in "@\n" are transferred. when the maximum baud rate is 9600, then some 100 Hz is the maximum pulse rate you can achieve with RS232 using this single shot mode...
The best and most accurate way would be to check the external trigger capabilities of your device like AnalogKid suggested. there are DIO devices for some 10s $. or you use your parallel port as trigger source (this deliverers also TTL signals, presuming your device needs TTL)
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 24 of 28
(1,351 Views)
@anjie wrote:
the SDG box
What is this SDG box?
Message 25 of 28
(1,021 Views)
Hi ybur,
you know that thread is ~3.5years old? And did you search on the mentioned manufacturers website?
Message 26 of 28
(1,004 Views)
@GerdW wrote:
Hi ybur,
So everything in the thread is obsolete? Is that what you are saying? What mentioned manufacturer?
Message 27 of 28
(998 Views)
If I recall, the SDG is a sync and delay generator for lasers and is (or ws?) made by Coherent:
http://www.coherent.com/downloads/ACF86A.pdf
-AK2DM
Message 28 of 28
(991 Views)
