Hi...
I'm making a program in LabVIEW. It uses several sub-VI's, and to keepe track of them all I've placed all my VIs in a VI Library.
Now I would like to be able to start my main-VI from a shortcut placed on the desktop, but I can't seem to create a shortcut to the VI, because it is inside the VI library. Inside the VI library there is no item in the "right-click-menu" where you can "Send to -> Desktop (create shortcut)". Is there any way to create a shortcut to the VI when it is inside a library?
Thank you in advance
Jesper Thygesen
