Can I make dll with cpp files?
Can anyone tell me whether I can make dll from a *.cpp file and call it from the call library function node in LV? I am getting this doubt bcoz when I right the Call Librarry function node, the calling convention is C and not C++.
Thanx & Regards,
Srini.
(3,137 Views)
Ofcourse you can. but not in LV. build a DLL from .cpp in C environment. you can also decide yourself that the DLL's calling convention will be stdcall or C.
Regards.
(3,130 Views)
Check out this previous post and be sure to read the External Code Reference Manual.
Jason
(3,123 Views)
