Can I maximize the front panel over multiple monitors?
I am using a Matrox G450.  I have the two monitors mounted one directly above the other.  Is it possible to maximize my front panel over both montors so that it completely fills both screens?
M. Adams
(2,895 Views)
I once had a two monitor system side by side that would allow me to expand the front panel or block diagram across both monitors.  I am not sure how to do it top to bottom.  The video setting for side by side was 2560 x 1024 or something like that.  If you can set your video to 1280 x 2048, that might work.
- tbob
Inventor of the WORM Global
(2,887 Views)
It is possible.  It depends on the software given to you by your graphics card company.  You can run on 2x2 in a square or greater if you like, for LabVIEW or any application.  It's not LabVIEW dependent.
I use Nvidia, you can support 8 or more monitors at once using their software.
(2,875 Views)
