Hello, from hardware I've got Multifunction DAQ (6013) and Therminal Block (68LPR). From software I've got VI Logger (1.0.1) and NI-DAQ (6.9.3). Using this, can I measure temperature with K-Type therminals? (Everything is installed and ready to go)
If yes, how can I connect K-Type therminal to thermal block? Are there any instructions on how to use VI Logger to perform similar task to this one?
Also what I want is, the temperature that has been read (for an hour, every 5mins) to be written in a file. Is it possible to write to a file using VI Logger?
Thank you!
Regards Slav.
