Can I move Add ins?
I don't know if I can describethat very well (I am learing LabView at the moment)
Is it possible to "move" the user specific Add ins?
So that they not appear in "right click  > User Libarys > Add in" but in "right click > Add in"?
I am Using LV 2011 and 2014 both 32bit and 64bit Versions and Windows 7 Prof. 64 bit.
(3,726 Views)
Tools->Advanced->Edit Palette Set.
I don't normally suggest moving things around in the palettes.  Just be careful.
(3,716 Views)
I agree. Don't go and move anything. Just create a new palette that points to the existing functions.
(3,711 Views)
usually I would agree, but it is for a test for my company to get our VIs faster, would it be possible to just "copy" the tool or create a link?
(3,706 Views)
We put all of our re-use libraries into VI Packages - with those we can specify exactly where the VIs appear in the palette menus (including icon/position/ordering). Maybe it would be worth looking at?
(blog)
(3,666 Views)
I solved the problem, I just add them manually in, and not drag n drop them in the user.lib .
The solution (from an earlyer message was correct) is like that: Tools -> Advanced -> Edit palette Set -> then on the Palette right click -> insert -> (the wanted VIs)
(3,565 Views)
