Can I open a VI using another VI
I'm trying to integrate multiple VI's into one VI. Is it possible to open a VI (open as in the VI pops open on the screen).
I'm very new to LABView and would really appreciate an elaborated explaination.
Kunal.
(2,951 Views)
There are 2 ways to do this.
1) When creating the VI that will be the sub-VI, from the menu bar, choose FILE, VI Properties. Then use the drop down menu to choose Window Appearance, and press Customize. Now click on Show Front Panel When Called and Close Afterward if Originally Closed. Now this VI will "Open" every time that it is called.
2) Place the sub VI icon on your diagram and right click on it. Now choose Sub VI Node Setup. Click on Show Front Panel When Called and Close Afterward if Originally Closed. This works for THIS instance of the sub-VI.
Hope this helps.
Rob
(2,951 Views)
Can i ask for this question, how do i actually call a VI? is it by reference node or by invoke node? i am rather stuck down here in trying to call the sub vi. Thanks and regards
(2,951 Views)
