This question actually belongs in one of the Measurement Devices categories. In the future, please post to the appropriate forum. You will find similar questions and get exposure to others with similar interests when you post directly into one of those categories.
In answer to your question, you can read the virtual channel properties, but you cannot programmatically change them. If there were a finite number of changes, you could have multiple config files that contained the same virtual channel names. Then, you could programmatically switch which config file MAX was using.
Alternatively, you can apply the scaling in your program if you read the raw value through the virtual channel (no scale) and then pass it into a scaling function.
You can find exa
mples for saving virtual channel properties to a text file and for changing config files in the NI Developer Zone. Start at the http://www.ni.com/support page and choose Example Programs from the Technical Resources pulldown menu. Then, type in keywords, such as "virtual channel" or "change NI-DAQ configuration".
Geneva L.
