Can I raed and write into an array simultaniously?
altenbach
All the peak values will be negative. I am rounding them off so that they can be used in generating index of an array.
Vipin
Message 21 of 23
(716 Views)
  • If all values are negative, just mutiply by -60 and eliminate the "absolute value" function.
  • The histogram is all integers, so make it blue (e.g. I32), no orange (DBL).
Message 22 of 23
(707 Views)
 altenbach
 Finally, Your suggestion of using a globally initialized node and using int32 in place of double worked out for me. Smiley Very Happy Thanx a lot.
I hope, I will also get to learn in future form You.
Vipin
Message 23 of 23
(694 Views)
