Can I remove vi link vi.lib when compile dll
Hi All,
To protect our code, I have to compile a set of my VIs to dll so that it can be called in my main vi. But whenever I open the main vi with the call dll function, there is always a warning message popped up such as
 " The subVI expected to be at "E:\Encrypt_All16_BD\System16.dll\Simple Error Handler.vi" was loaded from "C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Utility\error.llb\Simple Error Handler.vi".
There are total 5 such messages for different vis.
How do I remove this message popup, make sure the dll just calls my customized vi, and for rest, just call from the default folder \LabVIEW\vi.lib, etc?
Thanks in advance. LWZ
(2,733 Views)
see here
(2,729 Views)
