Can I reset an NI-RIO with an ethernet command?
I'm running an application running on a C-RIO and would like to implement a check in case that application aborts.  I've got an application on a host computer connected directly to the RIO that detects when it stops running and will <eventually> call for help.  I would like for this application to reset the controller, without using the FPGA or target code to assert the "system reset."  Does anyone know of a way to do this?  I think it's possible, as the Measurement And Automation Explorer is capable of doing just what I need.
Thanks in advance.
(2,467 Views)
It is possible to reboot your cRIO in your host VI on your RT target or on Windows. To do it, you can use Real Time >> Real Time Utilities >> RT Reboot Controller.vi
Message Edité par BenjaminR le 04-08-2008 03:49 AM
Message Edité par BenjaminR le 04-08-2008 03:50 AM
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(2,448 Views)
