Can I run 64 bit LabVIEW and 32 bit LabVIEW on the same machine?
If I have a 64 bit OS (Windows 7 64 bit or Server 2008 64 bit) can I install and run 32 and 64 bit LabVIEW on the same machine?
John
(3,285 Views)
LabVIEW 64-Bit vs. 32-Bit Applications FAQ
Q. Can I have both LabVIEW 32-bit and LabVIEW 64-bit installed on the same 64-bit machine?
A. Yes.
The FAQ will likely answer other questions you have regarding the restrictions and issues you will have with having both versions and compiling in one vs the other.
(3,265 Views)
