Hi Nibor,
You need to post this on the TestStand forum.
You dont need LabVIEW but you do need the correct version of RTE.
Are your VI's in the same position on the target machine as the development machine?
It could be a search problem and you may need to add the search path key to the LabVIEW RT Server ini file.
eg.
viSearchPath="C:\Program Files\MyProject;s:\*;
Regards
Ray Farmer
Regards
Ray Farmer
