Can I run a LabVIEW 7.1 Application on a system with LabVIEW 6.1?
The VI App did not run properly, even after I installed the LabVIEW 7.1 Run time engine. Perhpas I need to uninstall the LV 6.1 run time engine? Thank you for any suggestions; perhaps it's something minor that I'm overlooking!
(2,681 Views)
Are you talking about a 7.1 exe or VI? An executable will run with 6.1 installed and the 7.1 run-time. A 7.1 VI will only run with 7.1 development system. When you say it did not run properly, what exactly do you mean?
(2,681 Views)
I am referring to trying to run a 7.1 EXE application on a system with a resident 6.1 development environment, and the 7.1 run-time engine installed.
It caused my GPIB (HP 3852) to error.
(2,681 Views)
That shouldn't be a problem assuming that all the drivers (VISA, NI-GPIB, etc.) you need are installed. I haven't run a 7.1 exe yet but I've done it with 7.0 executables on systems with 6.0 and 6.1 development. What was the actual error code generated?
(2,681 Views)
