Can I set the number of visible objects in a indicator
HI
I have an Indicator of array of cluster, this is: a bundle of strigs to form a cluster, and this is Interleave in an array, but the numbers of cluster it is variable, and depend to the number of entered data, and I need to show the exact number of cluster
(2,668 Views)
Sirrick,
If I understand your question correctly, you want to programmatically set how many array elements (clusters) to show. You can do this with the Array properties: Number of Rows and Number of Columns. Please see the attached VI.
Zvezdana S.
(2,667 Views)
Thanks Men, you really help me
(2,667 Views)
