Can I set the window scroll bar position when a VI is loaded
I would like to fix the positions of scroll bars of the front panel when the vi is loaded, is it possible?
(3,175 Views)
Using LabVIEW 2019, they retain the position they had whenever you last saved the VI.
Is that not what you observe? Or just not what you want?
GCentral
(3,174 Views)
I would like a tab control (or the front panel (0,0) position) to be at the top left corner of the front panel window when the vi is loaded, no matter where it is when I closed/saved the vi.
It is just a "for convenience" question.
(3,158 Views)
Accepted by topic author TulaRen
I like to do this too. I tend to set the front panel origin programmatically on all of my top level vi’s to make sure that they are in the right position when I recompile the exe.
Have a look at this link. This is how you do it.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6wgSAC&l=en-GB
(3,127 Views)
Then you want to use a Property Node to set the Origin position.
You can also look at this link for more details: Programmatically Scroll a VI's Front Panel
GCentral
(3,122 Views)
Great! Exactly what I want to do. Thank you.
(3,113 Views)
