Can I start Web Server when VI runs?
I'm quite familiar with the Web Publishing Tool under the Options menu. I would like to not have to start the web server every time I open LV. I have only one VI running on a machine. Web Publishing Tool is correctly generating the html page. This VI is just running all day long and doesn't require any user input. I would like it if, in the event of a machine restart, some user could just run the VI and not have to worry about also starting the Web Server. Is there a way to do this?
(2,588 Views)
Accepted by topic author tir38
Hi tir38,
You can use property nodes to programatically start and stop the web server within LabVIEW.  Check out this KnowledgeBase article for more details.
Peter D
(2,586 Views)
