03-09-2009 09:43 AM
Hi all,
I'm using USB-6009, LV 8.5, under windows XP. I want to generate DO signals synchronized with AI. I know that I cannot use the sample clock as the clock of DO. But can I use the counter of the card to synchronize DO and AI? And can any one give some similar example? Thank you!
Best wishes,
Bo
Solved! Go to Solution.
03-09-2009 10:06 AM
03-09-2009 10:15 AM
Hi Dennis,
Thank you for your quick reply. But I have no idea about the "software synchronization", could you show me any example? Thank you very much.
Best wishes,
Bo
03-09-2009 10:20 AM
03-09-2009 10:27 AM
Hi Dennis,
Thank you for your advice. Then I'll set the generation mode of the DO task as "1 sample (on demand)", and use a loop to generate. Hope it works. Cheers.
Best wishes,
Bo
