02-22-2007 09:41 AM
02-23-2007 03:54 PM
Hi Ted,
Do you have each card's acquisition set up in a different VI Logger Task? This is the only way to accomplish logging from multiple devices.
Try setting up two VI Logger Tasks - one for each device's acquisition - and let me know if that works...
Nicholas B, National Instruments
02-23-2007 04:13 PM
Thanks for the Reply,
I can set up 2 different tasks, but this presents a different set of problems:
1) The tasks are not synchronous, so the time base for the two data sets
is not the correlated
2) It does not seem to like to run 2 tasks at one time
02-26-2007 04:41 PM
Hi Ted,
Since you have to run the two acquisitions in different tasks, they are run independently and cannot be synchronized. Is there a way for you to specify a start trigger for the task? Also, what do you mean that "it doesn't like running two tasks at once"? Does it slow down your computer performance? What are the specs of your computer?
