Can I transfer data through FIFO in two different myRIO FPGA Targets?
Hi GerdW,
How to implement PLL and what and how should I track with it? As I have told you that there are 16 digital output pins which are required for a single phase and are provided through the second myRIO. PLL will be implemented between two myRIOs and what the PLL will be doing there?
Ahmad
Message 11 of 12
(488 Views)
Hi Ahmad,
you said the 2nd myRIO should output a pulse with 240° phase to the 1st myRIO: so you could monitor the first pulse of your 1st myRIO (and its frequency) to adjust the 2nd myRIO to output it's first pulse at (more or less) exactly 240° phase…
That's what a PLL is doing according to the description at Wikipedia!
Message 12 of 12
(480 Views)
