Can I upgrade labview 7.1 to supported ni 9213 module
Hi every body
I am trying to use ni 9213 module with labview 7.1, i get a massage unsupported module. can I install a driver to upgrade the labview?
(3,211 Views)
@eraghubi wrote:
Hi every body
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
(3,203 Views)
Accepted by topic author eraghubi
According to that link (which is awesome by the way) the 9213 in a cDAQ chassis is only supported in version 8.2.1 LabVIEW, using DAQmx 9.0.
LabVIEW 7.1 is 11 years old released in 2004, it might be time to upgrade, there have been tons of awesome improvements over the years.  Of course if you need to upgrade the OS, and upgrade LabVIEW and upgrade DAQ you will probably need to upgrade hardware and the costs can pile up for sure.
(3,184 Views)
Thank you Hooovahh very much for this information.
(3,144 Views)
