Can I use CF6004 with Acer N50?
I want to use a CF-6004 board and LabVIEW PDA on a Acer N50.
I had try to connect board. but configration utility is not recognized device.
Can anyone tell me if this Acer N50 is compatible with CF-6004 and LabVIEW PDA ?
(2,722 Views)
Hello mostech,
The more important factor in whether you will be able to use the Acer N50 with the CF-6004 is the operation system of the PDA.  If this PDA is running Pocket PC 2003 OS, then this hardware will work.
If you can provide us a better idea of what you are doing when the device is not recognized, we can certainly help.  Keep in mind that the NI-DAQmx Base Configuration Utility does not exist on the PDA, only on the host PC and you need to import a task list into the utility for your specific hardware when using a PDA.  Please take a look at this knowledgebase article, as it explains how to import the correct task list.
Laura
(2,711 Views)
