Can I use DAQcard-500 with Xp pro and LV5.1.1
Hi I am running Xp pro, with labview 5.1.1 and I do not seem to be able to get a driver for my DAQcard-500.
Can anyone tell me if this is even possible, and if so how do i install it? because i can not get the system to recognise the DAQcard-500
Cheers
(2,438 Views)
I believe that card is supported by NI-DAQ 6.9.3 under XP: http://www.ni.com/support/daq/versions_portable.htm#du Remove card, install software and then plug card in and is should then be detected.
(2,432 Views)
