Can I use Lable 8.6.1 to check out files and manipulate them Using NI_SCC.lvlib
I am attempting generate some configurations and documentation files that I want to manage with SVN.  Does the NI_SCC.lvlib have the hooks to do this?  If so is there an example I can look at?  My main issue is the references (project refnum)
Any help would be great!
Rich
(2,917 Views)
Accepted by topic author rwelch
Yes you can use the NI interface.
However you will need an additional software module to talk to a SVN server (pushOK SVN).
Have a look at the connectivity->Source control  palette.
Ton
My LabVIEW Ideas
(2,912 Views)
I have SVN all setup.  I wanted to control it programmaticly.  I was getting hung up on the "project refnum" input of the SCC Open SCC Project.vi   If I leave it unwired all is right with the world!  I just figured that out.  I am all set!
Thanks!
Rich
(2,909 Views)
