Can I use Labview 5.1.1 and NI-DAQ 6.6 with the AT-MIO 16D?
I would like to add onto an existing program that was originally written in LabVIEW 5.1.1 and contains NI-DAQ 6.6. I would like to be able to use the AT-MIO 16D board as well with these versions. Would it function correctly with the NI-DAQ 6.6 driver?
(2,480 Views)
Hi
There are different AT-MIO-16Dx-xx boards, but with NI-DAQ 6.6 only the AT-MIO-16DE-10 is supported. You can see which board is supported with your NI-DAQ version if you look into the "NI-DAQ user manual for PC compatibles" of your Version. You can download it from "ni.com".
Luca
(2,480 Views)
