Can I use MinGW compiler for CIN ?
I would like to know if I can use MinGW compiler, which is a windows port of
the gcc (www.mingw.org), to compile CIN for Labview ?
I actually use Dev-C++ (www.bloodshed.net) which uses this MinGW compiler.
Does anybody has experience with this compiler/Labview or do I have to use
MS VC++ ?
Thank you,
Chang-Kwon Kang
(4,114 Views)
Check this "External Code for LabVIEW - CIN / DLL - Starting Point" [http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/a6705fec7ea42300862567b70054206e?OpenDocument]
Hope this helps.
(4,114 Views)
That does not seem to be the case. The header files ("platdefines.h") explicitly check for known compiler architectures and stops if the compiler is not known.
MinGW/gcc on win32 is not among the supported options (too bad b.t.w).
/jarek
(4,114 Views)
This is what I used to compile DLLs for Labview using MinGW.
#ifdef __MINGW32__
    #undef WIN32
    #undef _WIN32
    #undef __WIN32__
    #define linux 1
#endif
#include "platdefines.h"
#include "extcode.h"
#include "fundtypes.h"
#ifdef __MINGW32__
    #undef linux
    #define WIN32 1
    #define _WIN32 1
    #define __WIN32__ 1
#endif
This way I did not need to modify the platdefines.h header file. But Still make it choose the correct compiler GCC and architecture (you may want to verify it chooses the correct architecture on your machine).
Note I'm currently using Labview7.1 and have not tired this on any other versions.
-Pev
(3,566 Views)
