Can I use NI 8451 for daisy chained SPI? How?
Hi Experts,
I am new to Labview and now I am trying to find a solution how I can read and write SPI commands on a daisy-chained configured master-slave. The system I am using has 2 slaves. Each slave would need 24 bits per command frame and SCLK is at 400 kHz. Is it possible to use NI8451 for this problem? I would like to know because we would like to purchase this module if it can do the job.
I hope you can help me.
Thanks.
(3,402 Views)
If you go to NI's website (ni.com) and search for USB-8451, you will find a lot of information about this device.  The user manual specifies that it has 8 chip select lines, so it can handle up to 8 slave devices.  The document shows how to hook it up and how to use it.  There is a Labview driver library for this device to make your programming easy.
- tbob
Inventor of the WORM Global
(3,396 Views)
thanks for your reply. but this is a conventional SPI. I was asking if it is possible to use the USB 8451 for a daisy chained SPI configuration. In this case, there is only one slave select line for many slaves and each slave is connected in daisy chain.
(3,378 Views)
If you have only one chip select line, how do you distinguish between the devices?  I have never used a daisy chain for several slaves so I don't think I can answer your question.
- tbob
(3,372 Views)
Hi Lesly,
I'm also new to Labview and I've your same issue. I'm studing for a custom test system and I would to use some SPI devices (ADC and DAC). Since the number of devices could increase in future, I think to use a daisy chain SPI configuration.
Are you been able to work properly with a SPI daisy-chain configuration and a NI8451 device?
Thanks in advance.
Luca Buccolini
(3,099 Views)
