Can I use NI USB-6008 with LabVIEW 2021?
I found "NI USB-6008" Can I use with LabVIEW 2021?
I have just started using LabVIEW so I'm not sure if I can use it.
I appreciate your help.
Masaya
(1,259 Views)
Accepted by topic author Masaya1212
Yes, you can.
FYI, LabVIEW is a programming language. In order to use any hardware, you need a device driver that supports the hardware and also can be used in the programming language of your choice. Now, DAQmx is the driver that supports USB-6008 and the latest DAQmx driver supports LabVIEW 2021.
Santhosh
Soliton Technologies
(1,235 Views)
Dear Santhosh,
Thank you for your prompt reply. I appreciate it.
OK. Then I will use the NI USB-6008.
Thank you and have a great day!
Masaya
(1,225 Views)
