Can I use PFI1:5 as a DIO in PCIe6537?
Hi
Is it possible to configure one of the PFI 0..5 to behave as a standard DIO data line as any other data in Port0:3?
I have noticed in the channel control extra Port4/Line0:5, is that somehow related to PFI0:5?
thanks
Pawel
(2,626 Views)
Dear Pawel,
The short answer is yes, you can use your PFI lines as DIO lines. However, they can only be software timed. This means that they are not going to be able to run much faster that +/-10 khz.
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(2,563 Views)
Hi Efrain
Thanks for the answer.
(2,556 Views)
