Can I use UDP to exchange data between 2 VIs on the same computer ?
I try to use UDP (because I don't want to write a share_memory dll ..) to exchange datas betweend 2 VIs.
Is it possible ? (so far, it doesn't work)
Is there a better way to do that (and faster than write a shm in C) ?
thank you !
(2,712 Views)
Yes, that's no problem...If you search through the examples shipped with LabVIEW you'll fine VI's that exchange data via UDP and you can run them on the same machine.
Are the VIs in separate built applications, is that why you want to use a network protocol?
(2,712 Views)
Thank you for your answer.
yes, they are in separate built applications.
can it make it difficult ?
(2,712 Views)
