Can I use a Data Table to create a real Arbitrary Waveform for simulation within MultiSim?
Can I use a Data Table to create a real Arbitrary Waveform for simulation within MultiSim?  I have an equation derived in MathCad that I want to pass into my circuit.  Note that MultiSim's Agilent Function Generator is only psuedo arbitrary.
(2,778 Views)
Hi Serenity:
The Sim Arbitrary Wave indeed uses just such a table.  However, you do have to insert the data manually.  However, this is your lucky day.  I've "drilled down" into the Express SIM arbitrary Wave vi, and converted it into a standard VI.   From the block diagram, I replaced the ARRAY control with a Read Spreadsheet.vi. You should be able to put your wavetable data into a spreadsheet.  I've attached an example.  You might need to tweak it a bit, but it should get you started.
Let me know if you need any  more.
Eric
(2,752 Views)
