04-20-2007 06:24 AM
04-20-2007 07:18 AM
Is this for a Boundary Scan board (JTAG)?
We were calling the API (dll) from Labwindows-CVI. You should also be able to use the Labview-RT dll with CVI.
You can also launch your VIs from CVI through ActiveX automation. See the example program under cvi\samples\activex\labview.
Most posts talk about the reverse action... C/C++ dll being called from Labview-RT.
Hope this helps,
RayR
04-20-2007 07:21 AM
04-24-2007 03:41 AM
No, this is a PXI-CAN Card.
04-24-2007 04:18 AM
