Can I use a PXI-4351 in Vista?
I've recently replaced the pc operating my pxi crate with a pc with vista installed.  All hardware works now except my pxi-4351.  Is there a fix?
(2,678 Views)
Hi mpgreen,
The NI PXI-4351 only works with Traditional DAQ. Traditional DAQ is not supported on Vista. You will need to move back to XP to use your PXI-4351. There is a hardware driver available for the PXI 4351 for Windows 2000 and XP. I hope this helps.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(2,659 Views)
