Can I use a list of adress the with "open file" function?
In fact, i would like to get data into differents files in a folder. I would like to get it all, and put them into the same array with "read characters in a file" function.
(2,630 Views)
Hi Alexis,
You can specify a folder, get the array of individual files using List Directory function and index them in a for-loop to read them. Use Build Array with Shift-registers to read them into a single array.
See attached diagram.
Let me know if this not what you wanted.
Khalid
(2,630 Views)
Thanks Khalid,
I finally managed to make a loop using regisers. (kind of what you did).
Thanks again and good luck!
Alexis
(2,630 Views)
