01-08-2009 04:58 AM
Hi Jaime
Thanks for ur reply, the recommended article was a good peice of information. I have one more question, as mentioned in the article the use of "devisimulated property"done in my case ie. while simulating the pxi 6225 device gave the result as is simulated for 1st port ie firs 8 dio lines and not simulated for the next two ports. is this true or the trigger is not at all supported for any device. I am using daqmx 8.6 .
Would be waiting for ur reply
01-09-2009 09:56 AM
01-09-2009 12:01 PM
