Can I use cluster as Xcontrol data
I am Using a Xcontrol to make interface customized, I need to get a cluster output from the xcontrol.
I am Attaching the code I am Using Please Help me out in solving this.
I have Xcontrol and Xcontrol data  I have to get any modification in xcontrol should reflect in xcontrol data cluster.
Please run the printscreen.vi and check the result.
LV8.6
Regards
Dev
(2,786 Views)
You have to specify "data change = true".
Jean-Marc
(2,770 Views)
