Can I use third party Windows XP based touch panel module to control the system using cRIO
I am using cRIO 9023, and want to interface any other Touch panel Computer which uses Windows XP Embedded. If you could suggest me any capacitive type Touch panel Module or Touch Panel Computer??
(2,915 Views)
Axher,
The following link lists the supported Touch Panel Targets using the Touch Panel Module:
Archived: LabVIEW 2011 Touch Panel Module Help (Revision D)
Windows XP Embedded touch panel targets are supported, but not the full blown Windows XP.  To ensure that the system works the best, I would reccomend an NI Touch Panel Computers.
https://www.ni.com/en-us/shop/category/hmis-and-displays.html
Systems Engineer
SISU
(2,890 Views)
