I am running LabView RealTime 7.1.1 on a PXI Combo chassis as shown here:
pxi slot 5: PXI-6733 (used to test the slot 3 SCXI-1520 inputs)
pxi slot 6: PXI-6733 (used to test the slot 3 SCXI-1520 inputs)
pxi slot 7: PXI-6254 (two connectors, each going to the back of a SCXI-1520 in parallel mode)
pxi slot 8: PXI-6031E (controls the SCXI-1100,1102 through the PXI:SCXI backplane)
scxi slot 1: SCXI-1100 (operates in multiplexed mode with the slot 8 PXI-6031E)
scxi slot 2: SCXI-1102 (operates in multiplexed mode with the slot 8 PXI-6031E)
scxi slot 3: SCXI-1520 (operates in parallel mode with the slot 7 PXI-6254 left connector)
scxi slot 4: SCXI-1520 (operates in parallel mode with the slot 7 PXI-6254 right connector)
Is it possible to use two SCXI-1520 modules, both running in parallel mode, connected to a single PXI-6254 M Seriaes DAQ card?
