Can I use two SCXI-1520 modules with one M Series DAQ card?
I am running LabView RealTime 7.1.1 on a PXI Combo chassis as shown here:
  pxi slot 5:  PXI-6733  (used to test the slot 3 SCXI-1520 inputs)
pxi slot 6:  PXI-6733  (used to test the slot 3 SCXI-1520 inputs)
pxi slot 7:  PXI-6254   (two connectors, each going to the back of a SCXI-1520 in parallel mode)
pxi slot 8:  PXI-6031E  (controls the SCXI-1100,1102 through the PXI:SCXI backplane)
scxi slot 1:  SCXI-1100  (operates in multiplexed mode with the slot 8 PXI-6031E)
scxi slot 2:  SCXI-1102  (operates in multiplexed mode with the slot 8 PXI-6031E)
scxi slot 3:  SCXI-1520  (operates in parallel mode with the slot 7 PXI-6254 left connector)
scxi slot 4:  SCXI-1520  (operates in parallel mode with the slot 7 PXI-6254 right connector)
Is it possible to use two SCXI-1520 modules, both running in parallel mode, connected to a single PXI-6254 M Seriaes DAQ card?
(2,741 Views)
I dont see any problem in that...
because i have done similar things in past and they worked fine.
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(2,707 Views)
This question was answered previously
see here
http://forums.ni.com/ni/board/message?board.id=300&message.id=1644
Also see here
http://forums.ni.com/ni/board/message?board.id=170&message.id=157589#M157589
Note: disable SSH
Message Edited by devchander on 01-12-2006 01:23 AM
Message Edited by devchander on 01-12-2006 01:29 AM
(2,708 Views)
