Can Lab View send control commands to a servo motor using USB ports on a labtop?
Can we use Lab View 6i to send ASCII Text control commands to a servo motor using the usb ports on a computer or labtop.
(3,325 Views)
Hello invention:
In my opinion, you need a hardware that would connect your usb port to your servo motor.  I suggest for you to have a usb digital i/o and a driver / amplifier, then create a vi that would decode the ASCII text commands as output to your motor.
I hope this helps
(3,321 Views)
What VISA version do you have loaded on your system??
(3,313 Views)
Thanks for your help.
(3,296 Views)
I have VISA version 2.5 loaded on my system.
(3,295 Views)
