Can LabVIEW FPGA IP Export support Zynq UltraScale+ MPSoC?
I am really interesting to use my mathematic algorithms from my old Zynq-7020 SoC based sbRIO in a new Xilinx Zynq UltraScale+ MPSoC. Is it possible to generate VHDL for Zynq UltraScale+ targets via LabVIEW FPGA IP Export Utility?
(3,651 Views)
The documentation says the FPGA must be from the same family.  That said I have seen this get stretched if the functions being used are not too specific.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,642 Views)
I am using High Throughput Math Functions for example: Complex MultiplyRectangular to PolarSquare RootMultiply, Add for 16 bits fixed-point datas/numbers and some z^-k delay boxes. Aren't these too specific yet?
(3,626 Views)
@sz.benjamin wrote:
I am using High Throughput Math Functions for example: Complex MultiplyRectangular to PolarSquare RootMultiply, Add for 16 bits fixed point numbers and some z^-k delay boxes. Aren't these too specific yet?
Maybe try a proof of concept using the evaluation mode of this add-on.  Make a VI with just one of these functions and see how it exports and can then be imported.  Do you have VHDL/Vivado expertise?
ALE Consultants
(3,619 Views)
I have strong experiences in Vivado block design making and using them on AXI bus with Linux kernel drivers, but i have much less in VHDL coding.
(3,617 Views)
Then definitely worth a shot.
ALE Consultants
(3,591 Views)
