Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can LabVIEW Run-Time Engine 7.0 control LabVIEW 6.1 VIs?
joeljkp
Member
09-29-2003
08:48 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm attempting to remotely control a LabVIEW 6.1 example VI through the browser plugin on another system. On that other system, can I use LabVIEW Run-Time Engine 7.0? Or do I need 6.1?
0
Kudos
Message
1
of 3
(3,095 Views)
Reply
Re: Can LabVIEW Run-Time Engine 7.0 control LabVIEW 6.1 VIs?
joeljkp
Member
Author
09-29-2003
09:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Never mind, I should have read the RTE 7.0 information first. I need LabVIEW Run-Time Engine 6.1 to run LabVIEW 6.1 VIs.
0
Kudos
Message
2
of 3
(3,095 Views)
Reply
drval
Member
10-09-2003
01:15 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I have found that LVRTE 7 does support EXEs built using LV 6x.
0
Kudos
Message
3
of 3
(3,095 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
