Can LabVIEW change RT target IP address through LabVIEW scripting?
I am working on a Real time project, and for better usage I'd like to build an application to deploy RT VIs automatically.
After searching LV scripting for a long time I found the "Run and deploy VI" method which could deploy my RT VI to the target. But the question cames, how can I make this work if the IP address of My target changed automatically? I mean some of my users may know nothing about labVIEW programming, so change IP through LV project could not be an option...
Can LabVIEW change RT target IP address through LabVIEW scripting? Any work around is also very welcome! Thanks!
(2,763 Views)
Scripting generally not required but that depends on the architecture.
I have been deploying apps to RT targets based on the IP for years (LV 6i) but since then NI has stated to offer an RT deployment ( or is that replication toolkit) that helps out and you don't have to understand all of those switches in undocumented files to get it to work. CHeck with NI support/sales to get the tool.
Ben
(2,749 Views)
