Can LabVIEW generate a real time 1800HZ sinewave ?
Problem Description :
Problems:
1 When I used the" LabVIEW "connected to the" myRIO 1900", I try to generate a
"1800HZ sinewave "which amplitude is 1, to be the input of the "PWM" as the duty
cycle changing with the "sinewave", to control the "PWM"?
2: How can I run a loop smaller than 1 millisecond, for example, 20 microsecond?
3: Can the" myRIO VI " get and use the" gloable variables "from the" FPGA VI"?
(2,680 Views)
zyw,
For your first question take a look at this forum.
For the second question, that depends, I think it is better to understand timed loops, have a look here.
And last, you have various options when transferring data between RT target and the FPGA, you can see those here.
tuco100s
(2,625 Views)
